Bracing for quilted maple
http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=55076
Author:  nathanpeirson [ Tue Jun 14, 2022 10:25 am ]
Post subject:  Bracing for quilted maple
Hey folks, I just picked up a quilted maple back and sides from people liquidating their inventory. The sides are pre-bent and the back pre-braced. The bracing is much thicker than I have seen on other guitars (I will post a photo later). Is it normal to increase bracing mass for quilted maple?
Sent from my iPhone using TapatalkImage
Author:  meddlingfool [ Tue Jun 14, 2022 10:27 am ]
Post subject:  Re: Bracing for quilted maple
I don’t…
Author:  Mike Collins [ Fri Jun 17, 2022 4:53 pm ]
thats a martin style bracing
plane down the # 3 & 4 braces.
How thick is the back?
Author:  nathanpeirson [ Tue Jul 05, 2022 1:42 pm ]
Sorry for the long delay. I was on vacation in Kings Canyon...beautiful country...marvelous trees.
The thickness of the back is 0.110. The spruce top is also0.110. Not sure what kind of spruce it is but I'll add a picture.Image
Author:  meddlingfool [ Tue Jul 05, 2022 2:23 pm ]
Pretty thick for a back, pretty standard for a top…
Author:  nathanpeirson [ Tue Jul 05, 2022 6:00 pm ]
What thickness do you recommend for the back and sides?
Author:  meddlingfool [ Tue Jul 05, 2022 7:57 pm ]
I do most of my backs at .090”, and most sides .075”-.085”…
Author:  SnowManSnow [ Wed Jul 06, 2022 8:49 am ]
You could play baseball w that back brace on the bottom:)
Author:  Clay S. [ Wed Jul 06, 2022 9:10 am ]
The quilted maple back being a little thicker than commonly seen with other species doesn't bother me - it is a lighter weight wood, not particularly
stiff and sometimes will warp in strange ways if made too thin. I agree with Mike Collins - the lower back braces should be thinned enough to add some flexibility to allow the back to cope with humidity changes.
Author:  Alan Carruth [ Wed Jul 06, 2022 3:01 pm ]
Backs often work best when the two upper braces are tall and narrow and the two lower ones are low and wide. It's almost as if you simply started with them more or less the same and stood the upper ones on edge and laid the lower ones out flat.
